Royce Creasey
New Member
- Bristol, England
Thanks for these replies, I appreciate the effort.
I've got to the bottom of this problem now. Basically, I had assumed that the 140 was similar to imperial lathes I've used in past decades. (last millenium actually), where if you went back to the start line it worked fine Now, thanks to a chance remark on 'Haxby Shed' I'ver found the little data plate on the right hand end of the carriage. It turns out that some pitches, including the first thread I cut for a customer, align correctly on any line on the indicator. Some pitches only align on the numbers. One pitch only aligns on two of the numbers. The rest need the lathe to be reversed with the half nut engaged.
One of these pitches is 1.75mm (M12), naturally the one I chose while improving the tool grind. Hence my bafflement. To add to the fun this lathe is driven by an inverter that has lost the reverse function. So no M12 threads then. The lesson here? 'Don't assume, Check'
I tried using the carriage reverse, keeping the half-nut engaged but it's not accurate enough for thread alignment. Disengaging the clutch and turning the lathe backwards by hand is a pretty heavy job, I'll save trying that until there's no alternative!
less to think about! It took me ages to work out why it wouldn't work even with your description above. I'd forgotten about the relationship to the spindle
