Depends how flat your blades need to be, parallel too.do you need it, or is it more you just want one?
I keep being tempted by one, I need mincer blades/plates sharpening at work via surface grinder
but... it's only £6 each to have them done by pros.
yup brilliant tool,used one at the training centre as a lad , soo usefullAt last I have finished fettling the old Brown and Sharpe I acquired.
I have never used a surface grinder before. I love it! Working very well - not bad for 90 years old!
I could watch it all day.
I will have to video the back of it. There is a very long belt going over multiple pulleys. There is a pivoting counterweight which keeps tension constant no matter how high or low the spindle is. Don't want to get too close to it whilst running thoughIts like theres a ghost driving it ,,, what a thing of great beauty .
More than one ghost:Its like theres a ghost driving it ,,, what a thing of great beauty .
2nd one was the best - awesome.More than one ghost:
Look up the Rose engine.
this will boggle your mind ,,,
Very mesmeric !- not bad for 90 years old!
Any old grinder will grind a flat surface, whether it grinds a surface parallel to ways is another matter.
Hence when you flip the part, you end up with a trapezoid cross section.
yep thats the name they use for them ,,, reminds me of the big brass differential engine they used to use for tide tablesLook up the Rose engine.
Queen Victoria had such a lathe.
The work they could do was incredible.
£6 is cheap thenthere's 3 plates (the disks with hols in you normally see when you look at the front of a mincer) with 2 blades between them
they need to be pretty perfect, it's 75hp geared down to a few hundred rpm so it's happy to destroy them if they're not quite right
£6 is cheap then
Who is cranking it ? HAL ?
some amazing minds , basically a mechanical computer.
no idea ,,, theres plenty of videos of it working , even a video on how it actually works , an animation , im sure theres 3d printed small one by now , like those black wind up pocket calculators ,, or that Greek pocket computer they found laying on the ocean floorWho is cranking it ? HAL ?
and what was it set up to calculate for the video ?
