GraemeVW
- Chesterfield
I have a kerry super 8, got it maybe 8 years ago. I just stripped, cleaned and painted it than put it back together. It's been in use since but it's not very smooth.
I've decided I should do something about it, but not really sure what the issue is.
The quill is a good fit in the body. Doesn't seem to be much play. Without the drill running it's smooth lowering and raising the quill.
The bearings feel and sound good. Start it running and it seems great.
But, the two together, lowering the quill with the motor running you can hear it being very notch and you can feel the notch sound in the handle. It's like you can now feel the rack on the quill and it feels like it's lowering in steps.
I'm going to take it apart again, see if anything obvious stands out. I may put new bearings in it, but they seem fine.
Do the symptoms ring any bells for anyone that's rebuild drills before?
Once it's smooth I think I really need to find a new chuck too.
Any recommendations for something up to 13mm which is reasonably cheap? Keyed is fine.
Not had any luck with used Jacobs.
