CornishPete
- Huddersfield
Looks very compact and for a maximum of £58 a year it's great value! Always nice when something exceeds expectations, glad you're pleased with it!
Where's the quiver, where's the X factor?
Its very Ghost Busters , or Star Warsy ,, wait till the whole lot is in a hand held unit like off Aliens ,, then again it will probably be a plastic world by then , so a hot air gun would do , and Makita do one of those already ,,,
Don’t waste your time or money on itI'm on the hunt right now, I'm watching this one on fleabay, it claims a range 10-400A, too good to be true? There are no reviews so far, but heck it's so tempting at £87. What should I do?
Ok, it's difficult to choose, maybe I will get this one, https://www.ebay.co.uk/itm/28424316...mXMJBZEQPIWPB9Q==|tkp:Bk9SR97Gw-TjYQ&LH_BIN=1Don’t waste your time or money on it
Ok, it's difficult to choose, maybe I will get this one, https://www.ebay.co.uk/itm/284243166532?hash=item422e368544:g:vcUAAOSwhipjcNpL&amdata=enc:AQAHAAAAwGTXMN3X3P+C8vQcAeo6+9eW7dUd7YObFSf+DasQ7j5hlDdrJpas4s24a5iItm4PQUOlSNppt/1qe+MxqdJAzYujgXD7sY46QMTZxFMHMagsBboHrz+rcZUUE0BGuO/xKWB+jd0hS5ulLwLdJBn0lYc18V0CGToQqV1Q1qR+Xx2srSbGKB0fzw6VKCLpYHkxeHS9EglWXuadOg3B+1PA3ZHMkJL4tau7TpQJpdIxOutLTkCCVkImXMJBZEQPIWPB9Q==|tkp:Bk9SR97Gw-TjYQ&LH_BIN=1
if they are selling like hotcakes maybe they are good. But there is the 200A version for £10 more
MMA 200 INVERTER WELDER DC ROD ARC ELECTRODE STICK WELDING KIT 200A | eBay UK
Duty cycle: 100% @150A, 40% @200A. MMA200 STICK WELDER. - Suitable electrode size: 1.6-4mm. - MMA200 welder. - Efficient IGBT inverter technology. - Electrode holder, 2m. Welding & Cutting Machines.www.ebay.co.uk
if you read 200A apparently will be 160A, so if it's £10 more it doesn't hurt.Good luck with that. Chances are it'll never come close to 200a. It's the lovely Chinglish exaggerations methinks. And unless you are running long welds on 25mm thick steel with 5mm rods which I have never needed to do in my life then why would you need 200a? And if you are welding that kind of steel then spend the money on a good welder which can actually pump out that kind of amperage. And you'll definitely need a good supply for 200a - possibly a 32a supply. Other than that the suggestions by myself and others above are a much better starting point.
now look what you made me do, i had £71 left in pay pal which ive been saving lolOh, and I should probably mention, not once did the machine cut out from me exceeding the duty cycle when doing these welds. Obviously there was some setup each time but those long runs did not upset the machine at all.
i was going to get one of them as i have the ac/dc tig and the 180 mig but with the vat and postage it is 3x more than the draper to my doorThis is the R Tech offering.
Amazing little welder .
Sorry, I didnt realise you had changed your choice to the one from Static Arc. They were on my list to consider so I would be keen to know how you get on with the welder. It may well get the 200a it is rated for as I believe they are a decent company (though I have no personal experience of them). Perhaps you'll do a writeup of the machine when you have it.Good luck with that. Chances are it'll never come close to 200a. It's the lovely Chinglish exaggerations methinks. And unless you are running long welds on 25mm thick steel with 5mm rods which I have never needed to do in my life then why would you need 200a? And if you are welding that kind of steel then spend the money on a good welder which can actually pump out that kind of amperage. And you'll definitely need a good supply for 200a - possibly a 32a supply. Other than that the suggestions by myself and others above are a much better starting point.
I hope you enjoy it. I have to say my Thermal Arc has had almost no use since my micro Draper welder arrived. I am pretty sure it is plotting the demise of the little upstart. I have to say that I dont actually need the Thermal Arc to achieve the same weld standard now that I have the baby Draper (it's also a DC TIG so it's staying...). If you tidy up of the Dinse connectors, be careful not to tighten the grub screw too tight as the thread is right at the edge of the brass and I broke mine when screwing it back together.now look what you made me do, i had £71 left in pay pal which ive been saving lol
