It was in good shape except for the thumb screw that locks the jaws in position, which had broken off in its hole. I spent a few minutes to drill and 'easy-out' the broken screw and insert a temporary lock screw until I find a brass thumb screw for it. I stripped the paint, blackened the steel with gun bluing, and coated it with some melted beeswax. If anyone is into basin wrench esoterica, this bad boy was patented in 1876, and I found it listed in an 1878 catalogue, although it could have been made a bit later. All I know is that a 1905 catalog showed an updated design, so it has to be older than 1905.My motto: When in doubt, it's a lamp base.It's the base for a lamp !![]()
That thought actually did cross my mind, although I have some heavier-duty things from which I might eventually make a rotary welding table.Potential rotary welding table.
I'm still on a Liberty Tool Company roll here. This is a genuine, honest-to-goodness "Buzzell's Basin Wrench" that lightened my wallet by 8 dollars. I'll probably never use it, but I have a weakness for old tools, especially odd ones, and who knows when some weird situation might require its service.It was in good shape except for the thumb screw that locks the jaws in position, which had broken off in its hole. I spent a few minutes to drill and 'easy-out' the broken screw and insert a temporary lock screw until I find a brass thumb screw for it. I stripped the paint, blackened the steel with gun bluing, and coated it with some melted beeswax. If anyone is into basin wrench esoterica, this bad boy was patented in 1876, and I found it listed in an 1878 catalogue, although it could have been made a bit later. All I know is that a 1905 catalog showed an updated design, so it has to be older than 1905.
1878 catalogue link: https://archive.org/details/walworthmfgcocatalogue1878/page/n41/mode/2up
Patent link: https://patentimages.storage.googleapis.com/f8/69/d1/089cf21488fe01/US183901.pdf
Before:
After:
Grey. We're English, old chap.
In the 1876 patent text, the inventor says "The object of my invention is to produce a wrench which may be readily applied to the removal of nuts or screws in places that are not readily accessible to wrenches of ordinary construction.;" and the fasteners under a wash bowl or basin could fall into that category. A modern analogue might be something like this: https://www.amazon.com/TEKTON-WRN92004-Telescoping-Capacity-10-Inch/dp/B01D4ZF034A puller ? Extractor ?
Yeah, I bought one of the later ones some time ago. Got me out of some awkward situations over the years. It's almost universal that basin makers and installers don't give a rat's arise about the poor sod who has to dismantle their handiwork.In the 1876 patent text, the inventor says "The object of my invention is to produce a wrench which may be readily applied to the removal of nuts or screws in places that are not readily accessible to wrenches of ordinary construction.;" and the fasteners under a wash bowl or basin could fall into that category. A modern analogue might be something like this: https://www.amazon.com/TEKTON-WRN92004-Telescoping-Capacity-10-Inch/dp/B01D4ZF034
I am super happy with a big grin on my face!!potters wheel base ???Here's yet another item I got from Liberty Tool Company. The round top plate is about 5 inches in diameter, it was apparently driven via a V-belt, and the gear ratio is about 48 to 1. I picked it up just because it was fairly cheap, and it looked like it might be useful for 'something.' The top plate is a bit wobbly on the shaft, which I might fix. Does anyone know what it might have been used for?
I think it would probably work well with a speed control for use as a small potter's wheel. IF I were to use it for that purpose, I'd enlarge the bores in the frame to receive sintered bronze bushings, which would be easy to do, and make an enclosure to keep the clay out.potters wheel base ???
Congratulations! Next stop full ticket..... a pass in my intermediate examI am super happy with a big grin on my face!!
Cheers, I have ordered the 'full' book from rsgb and will start my training when it gets here!Congratulations! Next stop full ticket.
Better for you than cake !My Birthday today, a few more gifts:
A box of imperial and mainly unused Clarkson milling cutters:
and an "Indian" set of Matchless Clutch plates:
