Hi all
Is there a rule of thumb for the holes needed for plug welds ?
I have 2 tubes I need to join they are 1.5mm thick about 1.5" in diameter , I have a 3rd tube also 1.5 mm thick that is a cosy fit inside the other 2.
So the plan is to cut the inner tube to say 3" and plug weld it to both tubes first then do tacks around the centre joint till they are welded together.
What is the method used for a plug weld ? rods are 2.4mm
Start in the middle of the hole get the weld going and then move to the edges ?
regards Paul
regards Paul
