Onoff
- Sevenoaks, UK
Those trailcam cameras are not cheap are they.![]()
Have a look on Banggood.
Or Lidl. Mine was £50 ish from there.Have a look on Banggood.
We had a couple under the kitchen floor last year, don't know what the pest control chap used
A dead rat will stink summat awful whatever has killed it. Usually in a wall cavity, under a floor or where its hard to get at!
Fifty quid...from.lidl....wow.Or Lidl. Mine was £50 ish from there.
ive seen houses set on fire and a lot of chewed wiring literally blow up but never seen a dead mouse or rat due to it. they must have had there mushes burnt thoughCan't you just leave a half chewed up extension cord laying around ? (plugged in of course)
the plate is more sensitive to set it off. more chance of catching them as there a lot bigger and snap together . theres a chain on them as well you peg stop em running off if its just snagged and there not deadWhat is the advantage of using a Mk 4 Fentrap over say a traditional snap trap (A snap trap which is a rat-specific one..just looks to be bigger)?
one was even watching me when i was in the attic . flung a screwdriver at it and it just slowly scurried away
ive seen houses set on fire and a lot of chewed wiring literally blow up but never seen a dead mouse or rat due to it. they must have had there mushes burnt though![]()
Something like this any cop?They average about £80
Thanks Robbo, minimum range is probably the most important thing, doesnt say, but looks like puss and fox were quite close to the camera?
ThanksThey were about 2 - 3 metres away, the "ratshot" in post #21 was about a metre.
Brodifacoum wax blocks are good. My wife was Rochford councils pest control officer (ratcatcher) for ten years. Used quite a bit of it.
Main mistake people make with any poison is to put some down then not check it often enough & fail to keep topping it up.
As long as they are eating it keep putting more down. Warfarin still works but may need several meals before the victim has accumalated a lethal dose.
Brodifacoum they just need one meal & thats it.
Mice will dry out & dessicate without smelling much, A dead rat will stink summat awful whatever has killed it. Usually in a wall cavity, under a floor or where its hard to get at!
