prepman
- Gwynedd UK
Help!
Having a spot of bother with the Kuga brakes ....again. Had issues with brakes rubbing in past and replaced rear calipers which fixed issue Dec 2021. Prior to this the ABS module packed in and was repaired by a very reputable firm.
Now I've got rubbing brakes again..... I ran car then used temp gun to measure disc temps.
Front OS and rear NS were high ~170C.
As this is diagonally across and not on one axle is it likely to be an ABS issue?
Aren't they paired like this?
No fault lights. Will run diagnostics tomorrow, but very limited with the little unit I have.
