Arc Tourist
- Wales
Shocking thought isn't it.There simply are no reasonable words befitting that post.![]()
stack three mini rims ontop of each other few welds and job done ,, or four if your tallYes I hear ya!
I have far, far too many tools so my garage is very tight for space. A lump of tree carcass in the floor would be a deal breaker spatially.
It's also flammable so there's that too aka in a tight space I'd be welding next to it. I'll build a slim but very strong metal stand for my Anvil
whoever put those holes where they are has probably never seen an anvil , let alone used one .As always Amazon suggest stuff you have just bought
These don't look the same quality but get ok reviews
30kg - £100
50kg - £290
For the money I dont think you can go wrong, better still leave it outside to go rusty and you could double your money!It's here. 35kg. I believe it was listed as 38? So, 77lb in weight. Both holes are round. The obligatory mug for scale.I'm chuffed to finally have an anvil with a good working surface.
Are you going to bother some wood and build a stump for it Matt ?It's here. 35kg. I believe it was listed as 38? So, 77lb in weight. Both holes are round. The obligatory mug for scale.I'm chuffed to finally have an anvil with a good working surface.
Cool stuff!It's here. 35kg. I believe it was listed as 38? So, 77lb in weight. Both holes are round. The obligatory mug for scale.I'm chuffed to finally have an anvil with a good working surface.
I haven't done one for my small anvil yet, as I am also currently very limited on space.I am indeed. Already thinking about which approach to use to make a block for it.
Cool stuff!
It is listed as 35kg I think that was a typo on this thread title just.
Mine arrived 1st thing this morning. Very happy with it.
Fair bit of felling going on round here with decent sized logs piled up laying about, will have a scout around tomorrow for something suitable
Yeah, considering the unrealistic used market prices nowadays......................................................................... For the money, it was a no-brainer.
Did any of the packaging indicate country of origin? Should be made in Germany but dispatched from Belgium...
I already have 30+ hammers but go on then, what should be used on these ideally?So how goes the search for appropriate hammers ?![]()
