They come with the cable attached to get over part P i believe for the home DIYerWhatever you buy, open the box before you leave the shop. A lot of floodlights now have a dangling tail of cable that requires you to buy a waterproof junction box. You cannot open the light to wire the cable direct.
I have LED floodlights controlled by a single photocell controller.I always find it is the PIR module that fails well before the rest of the light. My preference now is a separate PIR sensor and light. The PIR sensors from Timeguard seem to last
If your not part P then you cant carry out any external works? with a pre-flexed flood a DIYer can scew the fitting to the wall, dill a hole through the wall, fit a 13a plug job done, if the DIYer has to start fitting flexes/cables to the fitting isnt that classed as external work?It makes no difference to part P whether it has a cable pre-fittes or not.
The pre-fittes cable prevents a lot of warranty claims for lights which have let in water when the installer damages the seals/puts too many cables in there etc etc.
none of it makes any odds if its your own property. if your pretty competent just get on with it.rewire your own house if you like .if u ever go to sell in a few years just get a periodic report done and test cert issued probably about 150 plus vatIf your not part P then you cant carry out any external works? with a pre-flexed flood a DIYer can scew the fitting to the wall, dill a hole through the wall, fit a 13a plug job done, if the DIYer has to start fitting flexes/cables to the fitting isnt that classed as external work?
Ledvance (Osram) are quite decent.
Never had any luck with LAP products.
