finyuk2005
So the folks' 1000 liter hot water tank has started leaking after just 8 years, he found it has rusted through.
It was about £1500 back then, likely a lot more now!
But we are hoping to have excess power from a 26kw solar array and a 6kw wind turbine fairly soon, and would like to find a way to put that into the hot water.
I wondered about doing a ground source heat pump set up, as we have plenty of field space available right next to the house we could burry pipes in.
Anyone know the best way of adding that into the system?
I wondered about using a smaller seperate hot water cylinder to pre-heat the incoming water before it gets to the pellet burner?
Or does an all in one system exist for such a task?
The other option would be to just use electric immersions, possibly even a 3 phase one as I have 30kw genny I would like to give a decent workout to every so often.
Also the Victron 48v inverter system is able to control contactors to switch the immersion heaters on and off depending on battery voltage and wind/solar input.
Any advice is greatfully recieved!
It wont be cheap, and even dad is agreeing with me that stainless would be a better option this time, as 8 years seems a pretty poor lifespan for such an investement!
cheers
cheers
