steveo3002
need to do some repair work on our wooden shed , the wooden bearers/crossmembers sit on concrete , would i be best to put some dpm barrier between the two surfaces
wouldn't the timbers still wick up water off the DPM? ...............ive got mine sat on spaced out pieces of slate the width of the timber base.Yes. Anything to stop the timber wicking up water.
yeah did cross my mind.....then i cant use creosote /engine oil on the timberMight be worth running a bead of Sikaflex EBT+ along the outside base of the wall of the shed and the DPM, to stop water getting in between DPM and shed base.
there also composite instead of wood
Plastic Lumber Joist 50x100mm | EnviroBuild
Heavy Duty support for your deck using Manticore Lumber recycled plastic joists - 50x100mm available in 3.4m lengthswww.envirobuild.com
My green house sits on 1/2 neoprene. I used Stock board cut up for the chicken coup, seems to have worked well. My shed sits on 1 layer of engineering brick, with dpm on top of the brick, woods nice and dryI sat my timbers on 9mm thick UVPC flat board cut down the width of the timber... still bone dry after 10 years
yes they need chopping out with a metal blade in a chopsaw as they can have metal shards in themare those solid plastic? I thought about using plastic decking to lift a walk in freezer off the floor - but a mate told me it's not solid plastic it's more plie plastic+mdf?
Yes basically thick gasket material. Just lifts thewood from the concrete and helps seal the tamped surface. Where as using recycled bale wrap, ie stock board, or the posts, is quite hard so can allow water underneath espescially on a rougher concrete finish^ whats that please 1/2 inch? neoprene ? is that the stuff light gaskets are made from etc?
