Forgot to mention, there is a dedicated forum over on Practical Machinist which is probably worth a read - https://www.practicalmachinist.com/forum/categories/transformers-phase-converters-and-vfd.11/
			thanks for the reply's........
a big enough battery set will cost over €15,000 euro's at the mo and who knows in the future.....
as for changing all the motors, to much trouble, then theres the cost of around €300 per motor..plus the switch gear....
where can I find details of a rotary converter build, thought it was a big 3 phase motor perm running in the backround and some capacitors.....
well not quite so....but u get the idea......
anyone here built there own system....
problem here is just getting stuff.....new items have to come from Germany-Poland etc.....and often dosen't arrive......
used stuff is almost unavailable....
It can be done without the use of a transformer. Watch the video that I posted (Tgere are 4, in total).There is also the issue as to whether you want to step up the voltage so you get full 380/415V 3 phase, rather than 240V 3 phase.
If you do, you'll need to find a suitable transformer.
I can't be bothered watching videos, so let me guess, he's only feeding two coils of the idler motor, and using the other 4 for generating?It can be done without the use of a transformer. Watch the video that I posted (Tgere are 4, in total).
Er...yes. Although I got the number of coils mixed up (I was thinking about a totally different motor!).No. The system starts with 240v across two phases, with a capacitor feeding the third. Once spun up, the cap. is briefly kicked out of circuit (since it's effectively a short circuit, and would damp and slow rotation too quickly), the 240v is then switched across one phase and neutral, and the cap. switched back in with an additional one feeding the third phase. This gives you a true 3-phase, with neutral. You need a star connected motor with the neutral brought out, obviously. It's on my todo list and I've already had a play with the configuration.
I set up a 220-240V rotary 3-phase converter about 17 or 18 years ago. I don't remember where I got the components, but as I recall, the idler control circuitry was preassembled and installed in the steel box. I seem to remember wiring up the receptacles, switch, mains cord, and idler connections. It uses a 7.5 hp Leeson/Gentec idler, with no external shaft. I wanted the converter to be portable, but have a steady base, so I modified a hand truck to accommodate it. It's still working fine and runs my mill and lathe smoothly. I wish I could give you more specific information, but it's been quite a while since I set it up. I do remember that I saved a fair amount of cash by buying separate components and doing the rest of the work myself. I might still have the instruction manual around someplace....be glad of some ideas please.......I have only limited knowledge of this kinda thing....Ta
I thought they were a lot more expensive. Are they still sold?I bought a 10hp digital drive, it drives my whole workshop. Here's some pics of it https://www.mig-welding.co.uk/forum/threads/lathe-swap.53699/page-26#post-647134
It runs all my 3 phase kit, I just have to be careful not to start the screw compressor and the big lathe with the 7.5hp motor at the same time. I bought the soft start option do it dampens the in rush current a bit.
Cracking bit of kit.
as ive said steam is more than capable
Yes, if you don't see what you want on the web site, give them a call, it's a small family business. You probably don't need 10hp if your biggest motor is 3hp.I thought they were a lot more expensive. Are they still sold?
My rotary converter can deal with normal starting loads so I didn't have to over spec the converter. It does what it says on the tin.I got a quote from Drives Direct years ago, and they were determined that I needed a grossly oversized digital converter that wouldn't give me much change from £7k.
Even with having to add an isolation transformer to my current setup, it's only cost me around £1200, however the 7.5kva isolation transformer would cost more than that now. It only cost me £425 delivered 3 years ago
I just checked the old emails.My 10hp was sub £1600 + VAT from Direct Drives, but that was 7 years ago. I guess it depends what you use it for.
well thats up to others what they pay outno one is going to fire up their steam boiler, wait for it to get hot enough then start running a steam powered generator every time they need to turn a 3 phase machine on?
its up to the owners what they consider there best optionI got a quote from Drives Direct years ago, and they were determined that I needed a grossly oversized digital converter that wouldn't give me much change from £7k.
