9" grinder would be quickerLump of 1" thick plate 9" wide needed cutting. Am I overdoing it on my 6" bandsaw. Oh well, love a lashup, so went for it.View attachment 379036
i use a dab of rocol on hacksaw blades and drill bits.cuts faster less friction makes blades last longer and less strain on electric motorsI remember the scrap steel shop I used quite a lot in the Philippines, they'd get old hydraulic ram arms in, 2 or 3" diameter hard chromed carbon steel. One old fella would sit there all day with a hacksaw, cutting them into 12" lengths to sell. Poor old chap must have been 70 at least.
One day I suggested he drip some oil on his worn old blade, him and the other guys all laughed, until he tried it.
Next time I went in he was there, sawing away, no oil in sight. You can't teach them a thing, they always revert to the old ways.![]()
not a problem if they have steel wheels some of the cheap ones may suffer and not suitableIf you lubricate the blade of a bandsaw how do you prevent the driving wheel slipping?
I tried a few drops of cutting oil on my newly acquired Lidl one and had to disassemble and clean it to get it to cut again!
I can understand using lubrication on a hacksaw or 'donkey' saw but a bandsaw??
My little Lidl one has 'rubber' tyres on the wheels so that may explain it.not a problem if they have steel wheels some of the cheap ones may suffer and not suitable![]()
Yes, I've done it for years, but my knowledge and experience counted for nothing when I try to offer advice to some local native who probably never did more than five years at school.i use a dab of rocol on hacksaw blades and drill bits.cuts faster less friction makes blades last longer and less strain on electric motors
I was once told to rub chalk into a file to reduce clogging. On aluminium I think. It made no difference.use wax
The amount of times I've been drilling steel and someone will be watching and they say " why do you keep stopping and putting that oil on there it would be much quicker to go straight through" I always answer " because iam an idiot "Yes, I've done it for years, but my knowledge and experience counted for nothing when I try to offer advice to some local native who probably never did more than five years at school.![]()
I’m thinking about a small compressor and nozzle on the cut - to blow the swarf away and cool the blade?I bought a 6 inch bandsaw years ago.
It wouldn't cut straight and kept throwing blades.
After getting advice on here I stopped using any oil and cleaned up the rubber on the wheels and it hasn't missed a beat since.
Last blades I bought were M42s from "Mr Bandsaw" and they have lasted far longer that the M42s I used to buy from "Tuff Saw"
The difference is in the quality of the joint, the Tuff Saw ones always strip teeth from the joint, the Mr Band Saw ones wear out.
Both are able to cut rail track with ease.
I'm sure both flavours would last longer with oil, but since I can't use oil, I can live with the reduction in performance.
When I tried a tiny bit of paste cutting compound or a drop of oil it will eventually throw a blade and stuff it, so it's a false economy for me.
My Startrite has one - called a chip blower I think. More for clearing the debris away than cooling.I’m thinking about a small compressor and nozzle on the cut - to blow the swarf away and cool the blade?
