i put an old screwdriver across the 2 terminals until they spark and crack...make sure its insulated thoughWhen working on something such as a single phase electric air compressor, what is the correct and safe way of ensuring that there’s no retained charge in the starting and run capacitors
That.I put my insulated pliers across a massive inverter dc bridge capacitor to check it was discharged once.
The bang deafened me, the flash caused me to be seeing a big green blob for quite a while afterwards, and my pants weren't too clever neither...
Got to be careful that it can take the load (hence my suggestion of a huge wirewound resistor).Just put a high value resistor across the terminals. Higher the resistance the longer it'll take to discharge but the less current it will pull so you don't have to worry so much about the current rating on the resistor.
Get Norbert to grab the terminals.When working on something such as a single phase electric air compressor, what is the correct and safe way of ensuring that there’s no retained charge in the starting and run capacitors
When we were a roomful of apprentices in the mod, it became a habit to “test” the insulation of certain types of capacitors (with a megger), then leave them lying around on the bench for someone to idly pick up and grab the leads. Apprentice instructor picked up one I’d planted one day, he wasn’t amused. I had to apologise (the mod was big on formal apologies for everything). I had to confess though, what I was really sorry for was that I’d missed the actual moment - he didn’t laugh at that either...Get Norbert to grab the terminals.
AVO Avometer 7 set to a high dc volt range, no arcs and sparks, and you can watch the volts go.
The AVO 7 is only 1000 ohms/volt so much quicker than an AVO 8 or dmm.
https://www.fluke.com/en-gb/learn/blog/digital-multimeters/how-to-measure-capacitanceTo safely discharge a capacitor: After power is removed, connect a 20,000 Ω, 5-watt resistor across the capacitor terminals for five seconds. Use your multimeter to confirm the capacitor is fully discharged.
Another way to discharge a cap is stab the end into your mates hand or arm...gets there attention like nothing else![]()
it dont half make them jump
i put a pair of leads on a cap i had . charge it up with the 500v megger and go prod someone with it![]()
But don't have it on current setting+1 for the above.
I also put a meter on them and watch the Volts go...
Moving coil meter - will do it quicker - but any DMM will do it.
