slim_boy_fat
- Scottish Highlands
Nobody around here can understand how he got away with erecting them
Brown envelopes? *cough... cough*
I wonder how many KW 8 standard poodles put out?Either.
I think some genuine research was done and it was noted 15 cats in a wall mounted cage should heat up the average living room.
Joking apart. Ive never been cold in a Pig stye or coo shed, its no wonder farmers the sleep above their stock. Maybe we need to start it again. Couple of Pigs and a Goat for what the Pigs wont eat. Happy days.About the same as the cats but if you cross breed the Poddles into Labradodles the extra heat from wagging tails is worth at least 5 extra cats.
It's complicated!
In a remote location I'd be inclined to just put a small wind turbine up.My cousin put in the ground heat source system when he built his house. It works really well but the pump has a very large motor that eats electricity. He knew this & was going to erect a small windmill to offset the electricity costs. But when he went for full planning permission for the windmill he was refused, even though they had said yes at first. He lives in the middle of nowhere with no near neighbours so no clear reason for refusal!
So he is now stuck with a big electricity bill until the planners get sense & permit the windmill!
Not many read and/or understand the ratings - and so rely on know-all (but often ‘no-nothing’) salespersons who are there to get a sale as their main objective (sales are money in their pockets!), so sell the most expensive kit they think the customer can afford - but which may not perform up to the expectations of that customer.
Back in the days of the Bastle house and Border Reivers thats how folk heated their house as well as protected their stock. Deep littering the floor also adds to the heat as its composting while the stock is adding poo to it.Joking apart. Ive never been cold in a Pig stye or coo shed, its no wonder farmers the sleep above their stock. Maybe we need to start it again. Couple of Pigs and a Goat for what the Pigs wont eat. Happy days.
As for heat pumps I thought they were only good for underfloor heating as a back ground heat. With supplement heating (Rads) from another source when required.
My friends brother had British Gas ring up “can we give you a quote for central heating” man came out & spent most of the day measuring up & sizing rads etc, than said “where does your gas come in” ”we haven’t got gas”I had a good example of that when we were looking at replacing the central heating system, had quotes from a couple of heating companies who told me what size boiler I would need and what size rads would go in each room, as I'd seen British Gas advertising boiler installs I thought I'd get a quote from them, the salesman sits there with his laptop working it all out and I asked what size rads would be fitted in each room, he just said "what size do you want?" they came out 30% higher than other quotes so didn't get the job anyway.
I believe the digestive system of a sheep causes it to emit around 1kw of heat.Joking apart. Ive never been cold in a Pig stye or coo shed, its no wonder farmers the sleep above their stock.
True but no windows and slits allowing air movment would deal with that!But folk didn't smoke so much back then (if at all) - think of all the methane collecting underneath the floors.![]()
Not quite the same setup but we had a simple wall mount AC “cool and heat” in our conservatory (outside heat exchanger). Heat mode was rated at 6kw output, don’t know if it actually gave out 6kw but it worked really well even down to -10 outside. Shorts & t-shirt in the conservatory:-)I have a suspicion that the over riding issue here is that air source heat pumps are generally cr@p when the outside temps are zero, or thereabouts.
I read the below or similar time and time again on t'internet.
Im confused, do you burn the rabbits/hamsters or cuddle them?
I think the discussion captures the key points nicely:
Existing houses are very badly built, in general, and that stops heat pumps being a viable option for most.
As ever, follow the money, who benefits from poor housing?
So the "con' is suggesting heat pumps work for badly insulated and sealed properties designed to consume oil, has and coal at fossil fuel shareholder acceptable rates.
I'll keep burning logs, I'll cut a tree every few years, job done.
Two legged in high heels or four legged ones with furry coatsEither.
I thought the cats were sent to fetch coal? The Moggy Miner was a well known thing back in the day.Either.
Tape the letter box up and make an external box instead .My oil boiler is set I think at 65degC. It's great and nearly 90% efficient.
Now though it's never off, struggles to keep the rooms at anything decent. Many factors why but mainly poor/lack of insulation and losses through the building fabric.
