addjunkie
- Northumberland. Reet oot in the sticks
Needs to copyright the name quickly before someone else does!Gaztube….take it as a term of endearment, you are famous![]()
Did that come with a heater?It’s very similar to mine ,except I access all the features via a remote control’,including switching it on and off. The red icon at the bottom shows the combustion chamber condition. It changes slightly when it’s running,basically showing if it’s lit and how much heat it’s generating
Have had an Eberspacher on the boat, a Autoterm/Planar in the camper van, and now a Chinese (Vevor) in the shed, all 2kW:Quick question to everyone that has either a Chinese diesel heater or a webasto/eberspacher variant
How noisy are they to have on?
I don’t have oneNot that noisy , you have silencer on exhaust?
For the price they work well and all of the ones I know of have lasted at least 2 years others 5
webasto's are expensive and so is the wiring loom for themI don’t have one
I spoke to a lad next door that has the webasto in his camper and he said you can sleep with it on at night as it’s so quiet
Will keep an eye out for one of them
The Chinese one is much, much louder than either of the others - the exhaust isn't a problem, it's the fan noise that comes from the hot air side - it sounds like someone hoovering in the next room. Doesn't matter so much in the shed,
Iv worked on horseboxes with webastos years back they just worked every single time with no issues. I will still think about the cheapy ones just prefer one that I can buy once and keep for when I build my camper conversion as the racing season gets cold towards the end of the yearwebasto's are expensive and so is the wiring loom for them
many buy the chinese type there good enough and have easily replacable parts for them
if you want less drone from them fasten to a solid surface anything that can echo will echo with them
if it says 5kw or 8kw its a lie they dont exist as there under 5kw output with a heat exchanger on them you can add water to them and also use radiators as well as they output at 100c+
Buy 2 - always have a backup - but mine have been faultless.Iv worked on horseboxes with webastos years back they just worked every single time with no issues. I will still think about the cheapy ones just prefer one that I can buy once and keep for when I build my camper conversion as the racing season gets cold towards the end of the year
Id prefer to buy it and its quiet from the offBuy 2 - always have a backup - but mine have been faultless.
The exhaust sounds like a jet engine running - in the day you don't notice it outside as traffic noise is louder. Noticeable at night but as long as the exhaust is outside it will be fine. Pump can give an annoying thump thump through solid surfaces so mount it on something to absorb the vibes!Quick question to everyone that has either a Chinese diesel heater or a webasto/eberspacher variant
I meant reliability wise not noise - they all sound the same!Id prefer to buy it and its quiet from the off
I have an eber D2 in my pickup.Iv worked on horseboxes with webastos years back they just worked every single time with no issues. I will still think about the cheapy ones just prefer one that I can buy once and keep for when I build my camper conversion as the racing season gets cold towards the end of the year
Planar aren't cheap chinese though.That is expensive, for a cheap chinese diesel air heater. It would have to be a HUGE special offer to get down to 80 quid delivered from the likes of vevor (but it would be a better product than the cheapy).
Neither of mine met the specifications and there may be issues with the build quality - but I knew that before purchasing.![]()
