Realistically I only need to break concrete. Of the two machines linked to, the MacAlister seem to be a decent breaker, 1700w motor. I did feel a bit unsure about the non-replacable carbon brushes?? What is the fix when they ware down?Do you want to drill and break or just break.
If you want to just break concrete then these are awesome. Broke out approximately 50sqm of 150mm reinforced concrete in my back garden and still going strong.
Error 410 | Screwfix
Thousands of products at low trade prices | FREE next day delivery available | 30 day money back guarantee on all orders.www.screwfix.com
If you want the ability to break and drill you need an SDS or SDS max drill.
A big SDS is ok for breaking concrete SDS max is better but both are slower than the proper breaker. But can drill holes as well which the breaker can't.
Titan TTB571SDS 7.7kg Electric SDS Max Drill 230-240V - Screwfix
Order online at Screwfix.com. The Titan TTB571SDS 230-240V Max drill delivers versatility and power, as well as excellent value for money. Featuring a variable impact rate and depth stop, this tool is suitable for a wide variety of different surfaces and comes with a selection of drill and...www.screwfix.com
Good questions.What sort of size breaking are you doing? Will it all be with the tool pointing downwards? Or will some be horizontal and some upwards?
Electric breakers come in roughly four sizes: SDS plus, SDS max, approx 15kg (e.g. https://www.screwfix.com/p/mac-allister-msbr1700-a-16-2kg-hex-shank-electric-breaker-230v/623HV) and big (e.g. Hilti TE2000), equivalent to a road breaker.
To get any kind of meaningful advice, first select your size.
Thanks for that tip.How thick is the concrete you're trying to remove?
I've broken up a couple of concrete floors with one of the Titan Screwfix SDS units mentioned above and they work quite well. I wouldn't use one if you're talking 6" thick concrete though, you'd be there all day.
One job is trimming off some over-hanging concrete of up to maybe 4 or 5 " thick, maybe 3 meters long. Preferably in a roughly 'straightish' line is ideal. Does not have to be perfect, just tidier than the current jagged edge. I did try to drill a line of holes prior to the sledge hammer. I burnt the armature & field on my Makita hammer drill, lesson learnt.
Another job is to break up a small path area that floods when it rains heavy, from my back door to the grassed back garden. There exists above ground a 3" dia plastic pipe which is supposed to take the water to the front to soak away on soil. It has never worked, and I want to make some sort of soakaway where the rain falls/runs to. This is maybe 3 or 4" deep concrete, maybe just a few sq feet in area. It is worth me putting the time in, and the only cost the breaker. I will save up for the electric![]()
Agreed, especially for the first task where you want a reasonably straight edge. A breaker will just destroy everything and leave you with little lumpsIt sounds like a 9in grinder and diamond wheel might be just as important as a breaker.
. You don't need to cut all the way through with the grinder, a couple of inches would do it and then use the breaker to split it along the cutI understand your logic.Is it just a few small jobs then that’s it?
What about hiring one? I hired a Hilti TE75 after the crank broke on my exact same one. £40 a week.
I used to use mine about twice a year so at that hire price I might not even repair it as the bits are loads more than a few weeks hire.
I've got one these and they're a great bit of kit. I believe the brushes are replaceable.Realistically I only need to break concrete. Of the two machines linked to, the MacAlister seem to be a decent breaker, 1700w motor. I did feel a bit unsure about the non-replacable carbon brushes?? What is the fix when they ware down?
This is a good endorsement for the Erbauer ebr1750. However, having read the reviews on the Screw fix site it is a 'mix bag'.It depends on how thick the concrete is? The small 7ish kg "breakers" are good for hacking off render or chipping through small areas of concrete, dig out the odd fence post etc.. but they're just big drills really. If you've a big slab of 4 or 6" thick to break up you want one of the 16kg ones. I had a Macalister one I gave to my dad which was ok but got the Earbauer ebr1750 from/by Screwfix to replace it which is hands down better. I'm a builder and have used it extensively on many jobs. It's been reliable and goes through slabs with ease. I've even used it to break up a 15" strip foundation, I thought it would struggle and only gave it a go on the off chance fully expecting I'd have to hire something more heavy duty. There's nothing so far it hasn't done! It's £200 at the moment and will have saved 1000's hiring breakers at £50 a time. That is incredible value for the performance, which is only marginally lower than a hydraulic breaker, and it saves lugging a hydraulic pack about. It probably had a decent warranty too but it'll be way out of date by now. I really can't rate it highly enough!
Erbauer EBR1750 15kg Hex Shank Electric Breaker 220-240V - Screwfix
Order online at Screwfix.com. Versatile tool with anti-vibration technology, an electric brake and adjustable speed settings for maximum control. Chisel function: choose between pointed or flat chisels to suit the job at hand. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
I will do a search for them.Aldi currently have 1600 and 1900W jack hammers reduced. Both down to £79.99 each.
