bigegg
- Leeds, West Yorkshire
I have a question, but I don't know enough about the terminology to ask Google...
Is the "network speed" on a LAN an overall speed? Or per connection?
Eg:
If I have 3 PCs - call them "A" and "B" and "C" connected to a switch, then that switch connected via a single cable to another switch which also has 2 PCs +"D" and "E" connected.
(Assume everything, individually, allows say, a 1gb connection).
A -> B 1gb.
A -> D 1gb
If I transfer files from A-B, and simultaneously transfer C-D, will the 1Gb throughput be split in the first switch between the two connections, or will each have full speed?
If I install a second cable between the switches, can I connect A and C at full speed, and ALSO connect B and D at full speed? (Or, again, is the throughput split between the connections?)
If it makes any difference, the DHCP router is connected to the same switch as A,B, and C.
Ta.
Eg:
A -> B 1gb.
A -> D 1gb
Ta.
