Hi,
As langy has said the threaded insert you are after are not normally made out of square bar. The wishbones and bits and bobs are normally made out of round tube. I know because i have made them in batches for various business in that sector. The ones i have made in the past use 1/2" and 7/16" unf threads, i think that is the standard used in the main.
No reason why they cant be made in square if that's what you need. I might have some in round knocking about in my works if its any use to you, i will have to check.
Edit: I should add these are for road going kit cars not a home build buggy, so may not be the same thing you are after.
Kind regards,
Scott (ward eng)
Kind regards,
Scott (ward eng)
god luck with your project.
