Milking machines use a vacuum pump & the recommended oil is an iso 32 oil.
Well this should be used after the refrigerant is removed with a recovery pump.its basically this type of generic pump, but even 2,5 cfm:
it does have the same exact oil bottle though, so maybe it means iso 100 then and if a "compressor oil" is iso 100, then i can use that too?
and does it even matter if the manual says its "for" 410a or 134a, because i could just use it for both of them?
They do typically smoke, it water vapour as its been boiled off at low presures and the pump oil volatilesHave a similar pump for the vac chamber, using the supplied oil. At low pressures the oulet smokes, but this may be volatiles coming out of the rubber sheet I'm using as the chamber seals. Sorry that doesnt help much..
Proper rotary vane oil for these pumps appears a bit expensive, however the wrong stuff shouldnt damage it, rather just limit how much vacuum you can pull.
yes i know, but the manual just writes that, so maybe there are just some pag oil? residues that might mix up in the pump or smth...
or at the very least i could just replace the oil then, when i switch between the 2 types?
Yes most compressor's and vac pumps use an iso100 hydraulic oil. But don't use it in a HVAC high vac pump.now there is some hydraulic pump(?) oil sold as iso vg 32, so does the same exact 1 oil/standard fit to 3 different types of devices - hydraulic stuff, compressors and vacc pumps?
a high vac hvac pump is used for removing moisture from refrigeration/AC systems it pulls a much lower vacuum, They are not rated for continuous use and need a specialist oil. a standard vac pump [there are many types] can run continuously, dosent pull as low a vacuum and dosent need a special oil.what is a 'high vac pump' and is it somehow different from a regular 'vac pump' and is the regular 'vac pump' an 'hvac vac pump' too, just somekind of 'hvac low vac pump' then?![]()
