Try swapping them over and singling them when the lights switched onIf they are fluorescent try the starters they are cheap enough?
check the voltage to the fitting make sure its over 240v there probabl;y just knackered even though hardly used. probably have 2 year warranty on themthey are the led ones . Tool station cheap ones.
i disconnected the back one to see if it was just it but the front on started.
yes should be ok but it was just worth checking your voltage to the fittingscheers. i will check. if voltage below 240v. will led strips be unable to be fitted?
probably not its pot luck on cheapish fittings. i never fit them and pay more for them with guarantee. i fit hundreds of them and if a load went faulty id have to go replace them free / fitting 50 pannel lights next week in a school . in the last 100 ive fitted had 2 faulty ones which isnt badwould the replaceable tube led lights be any better? or is there no difference between the two?
i will still check voltage though
