Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
I briefly tried magnetic attachments, but the arc pull made me give up with them.
When I was a computer etc engineer, we installed cat 5 and computers on an industrial estate into a printing company.
All went well until one lady complained her monitor was wobbling occasionally.
You ever welded used drill pipe? That’s fun.
You have to wrap the return round it by the weld to counteract the magnetic field in the pipe.
had to get a specialist de gaussing
company in to do some 4 inch pipe at a spool base could hang a tig wire on it and no way could you root it , be around 40 km of it , sat in the teahut for a week gettin paid
apparantly if the drillpipe is stored n/s direction through time it will
go magnetic so a yank told me ???
I think you may be mixing up magnetism and electrostatic charge?
It’s because it rubs in the ground, apparentlyThat doesn't sound right to me. Much more likely to become magnetised in operation. Especially when a long length is pulled out of the ground. The equivalent of rubbing a stick of amber on your jumper.
I need mind bleach….PS If you rub me the wrong way I don't become magnetic (quite the opposite) but I can become highly charged!![]()
I have those as well bit of 22mm flattened and bent at 30 degrees, however I'm currently working at the front left of a car so I would have to hold it with my right hand and weld with the left. I'm getting on a bit so I steady my right with my left and although I love Ronnie O'sullivans snooker playing I can't do what he does.Where you CAN use them, try having a bright light behind the weld/gap and then use a length (bout 12 inches) of copper pipe with the last 2 inches flattened. Now just before you go to tack place the flattened end of the copper pipe up to the fine gap in the panel. You will know where to tack as the light will be blocked by the copper pipe and it should also cut down on blow through.
Bert
Can't reach it it's on a spit, could do it upside down but why would you of learn to do that when you have a spit, at the mo it's nicely at chest level and 30 degrees.Lie on your back.![]()
Bert
If it's on a spit surely you can turn it over.
Anyhow this conversation has moved away from electromagnetism and lost its attraction.![]()
Interesting is there some chemistry involved? albeit that I remove the 'weld through primer' from the 'plug-hole' with a glass fibre pencil beforehand to keep the weld as clean as possible, wish someone would develop a glass fibre pencil to fit a pistol drill.
Bert
Yep, poles apart now.Anyhow this conversation has moved away from electromagnetism and lost its attraction.![]()
