sort of like hazel nut flavored squirrels ,,,I belive it is the insulation on the wires I belive the coating is plant based and tastes ok to the critters although I’m not sure if it is the norm or if there is another insulation that they don’t like.
Its close enough for science and an Electric Barberella.Is that the Duran Duran from Barberella?
Hard / unsightly to apply for string lights, pond pump etc, but will look at that for one problem area entering shed, although ministry of aesthetic will want it in floral finish..Yep! Conduit or Trunking![]()
The dog will likely try and eat it - and lose, Greyhounds, not good mousersI belive it is the insulation on the wires I belive the coating is plant based and tastes ok to the critters although I’m not sure if it is the norm or if there is another insulation that they don’t like.
Rats can't resist wiring in newer cars: Here's why
Rodents, such as rats, can get under the hood of vehicles and chew on wire coatings, causing problems with everything from headlights to fuel sensors.www.freep.com
no idea why, can't stand the neighbours
only a couple of mice . one stuck behind a socket and one behind a cooker its a.rse was stuck on the main terminal and its nose on the cooker casing burning away it stunk
I think they are called Kebabsin all the years ive replaced damaged wires that have blown up never seen a rat or mouse electrocuted by itonly a couple of mice . one stuck behind a socket and one behind a cooker its a.rse was stuck on the main terminal and its nose on the cooker casing burning away it stunk
yep ,, im sure they would rather be lions , or the likes ,,I suppose a lot would feed them with something else. Just need to put up with dead rodents around the place - and hope that cat does not get poisoned by eating them!
That's proper old school, look at that wall thicknessThis burst after I was climbing on the old kitchen sink cupboard during the house extension. View attachment 367511
The little git must have chewed just enough for it not to leak until I disturbed it!
It's alkathene and took a while to work out what size it is![]()
