slim_boy_fat
 - Scottish Highlands
after I lent it to a friend![]()
Are they now a former friend?
I though that biro balls had small holes/pits in to transfer the ink from the plastic ink tube round the ball to the paper ??No pics, but anyone looking for a very small ball bearing as I was 'cos there's one missing from a DTI!
Those from medium ball point pens are approx 1mm diameter (0.99 mostly) and fine ball points are 0.80mm.
Five each side have to be better than five one side and four the other! Just have to fit them in now.![]()
you need a repair cafe. Just like we have in Burntwood and Lichfield!My daughter has just moved into her first home, and being a student she is short of money. We found her a nice 3 seater leather sofa with electric recline, except one section didn't work, so it was sold for only £50
It was delivered today and I tried it out, the duff part just made lots of clicks when the button was pressed, which seemed to come from an electrical box underneath. I unplugged the wires, took the lid off the box, saw it was a electronic circuitry and promptly put the lid back on. Too complex for me.
However, when the sofa was put back upright and I pressed the switch it miraculously works perfectly.
I can only imagine a wire was loose, so it may well not be 'fixed' permanently.
...to transfer the ink from the plastic ink tube round the ball to the paper ??
Couldn't see any holes or pits in the ones I investigated, just looked like a very small ball bearing. All back together and working perfectly now.I though that biro balls had small holes/pits in to transfer the ink from the plastic ink tube round the ball to the paper ??
				When we bought it my plan was to swap the working gut's out of my own electric recliner sofa, if a repair wasn't simple. I never recline mine.you need a repair cafe. Just like we have in Burntwood and Lichfield!
Oh and the belt broke on my tumble dryer, So I fixed that. Why do they HAVE to put so many self-tapping screws in is beyond me.
I caught mine before it got that bad - had it blasted then I epoxy painted it, followed by 3m shultz, followed by lots of cavity wax inside it. Had to remake those little bumper hangers - they had gone too far.Today I fixed a front subframe from an Alfa 159 I acquired.
Seems a common problem so I thought I'd sort it before it became terminal.
Someone had treated and painted it before.
I still have one M14 bolt left over . . . I have no idea where it is supposed to go, but five years later, nothing has fallen off . . .
I had to pull the engine and box to get to the add on box that sent the drive to the rear when the output shaft bearings lost preload and failed - seemed a good time to sort the subframe out. Took the opportunity to replace all the V6 timing chains, guides and tensioners from GM online place in the USA - 200 quid or so rather than £2000 from Alfa.
Rest of the car seems pretty rust resistant - but the wafer thin coating on those subframes . . .
I've some very expensive chrome paint I want to try out.
Dunno. But, genuine question, are they gas filled?Not so much "made" but "re-purposed". For ages I've kept 2 biggish valves from a Scania Genset Engine that were replaced.
Today I tacked a bolt to the head so I could put the Valve into my pillar drill upside-down (no Lathe or clue how to use one), so I could apply a grinder to the shaft and point the ends to turn a valve into a large Centre Punch.
Not sure if the points will be hard enough though? Is there an easy lo-tech way I could Temper/Harden the tips?
