yep ,, I find it does ,, try panel clamps for butt joints , or good old vise grips etc for everything else ,,Mig welding thin metal sheet together 22 gauge, I put a piece of brass behind to prevent blow through and a neodymium magnet behind that to hold all together. Does the magnet drive the arc off?, my school boy physics tells me why it may do.
Bert
they are so handy ,,, tidy job.
Cheers.they are so handy ,,, tidy job.
You ever welded used drill pipe? That’s fun.I had a WTF? moment with TIG untill I realised I was welding next to a magnet!!
Had to look up what that was. Still not sure but I think I have just ordered a couple of thousand foot of it... oppsYou ever welded used drill pipe? That’s fun.
You have to wrap the return round it by the weld to counteract the magnetic field in the pipe.
What’s it officially called?Had to look up what that was. Still not sure but I think I have just ordered a couple of thousand foot of it... opps![]()
I am not a drillist. I worked on the ships that contained the drillists and their drill rigs. I got to fix their **** though. Yay me.
Why is there a magnetic field in the pipe? Is it a design thing or a result of being used?You ever welded used drill pipe? That’s fun.
Result of being used. It’s because it rubs in the earth.Why is there a magnetic field in the pipe? Is it a design thing or a result of being used?
I have a set of these,I thought at the time that they promoted blow through the weld puddle would blow round each side leaving the stitch, this may be a question of technique or the helmet I couldn't see through at the time, I've since purchased a trucolour helmet might have another go. but there are situations where they cannot be used e.g plug welding.
I’ve never had that problem I must admit.I have a set of these,I thought at the time that they promoted blow through the weld puddle would blow round each side leaving the stitch, this may be a question of technique or the helmet I couldn't see through at the time, I've since purchased a trucolour helmet might have another go. but there are situations where they cannot be used e.g plug welding.
Bert
Where you CAN use them, try having a bright light behind the weld/gap and then use a length (bout 12 inches) of copper pipe with the last 2 inches flattened. Now just before you go to tack place the flattened end of the copper pipe up to the fine gap in the panel. You will know where to tack as the light will be blocked by the copper pipe and it should also cut down on blow through.I have a set of these,I thought at the time that they promoted blow through the weld puddle would blow round each side leaving the stitch, this may be a question of technique or the helmet I couldn't see through at the time, I've since purchased a trucolour helmet might have another go. but there are situations where they cannot be used e.g plug welding.
Bert
