8ob
- Nescient in the vale
You don't - he was only meant to go under the patio but he ended up going via everything else in the process...How do you steer it?
They keep straight in most ground. But light sandy soil with large flint's can be a big problem.How do you steer it?
there in deep s.hit if theres any boulders in the way
A bit of skill and a lot of luck !How do you steer it?
We were struggling to mole under a road due to rubble/boulders and , after nearly losing it a couple of times .There are a lot of service layers out there moonlighting with the short versions of these machines, they take chances and get into all sorts of bother trying to go shallow. Our 125 machine properly set up in chalk at the correct depth which is a minimun of 10x the machines diameter did a 50mt run and was within 6mm, thats not bad. I bought these machines and they are way too expensive to take chances, not lost one yet.
Bob
How do those work?
