AVI_8
- Prestwick
Around £10 per hour by my calculationsI've got a 3 phase 30kW fan heater which warms the workshop up in no time, but I imagine that'll be a little pricey to run this winter.![]()
The instructions for mine says diesel or paraffin, don’t know where you’d buy paraffin these days, pretty sure it’ll run on pretty much anything other than petrol.One I have (same type burner but direct heater) recommended either kerosene or diesel but only to leave it off-line with one or the other - but cannot remember which.
One heater I have needed a new air pump rotor. Got the part but not yet sorted it. I may get round tuit one day….
I fixed the electric price last year so I'll have to see what the rate is. That said, if it's cold enough to need a heater that size I'll either use it and cost be damned or if whatever I'm doing isn't urgent I'll go home.Around £10 per hour by my calculations
id advise checking the heat output of that before sticking it out the window if its too hot you will melt the plastic window if you have that installedI was looking for an indirect space heater for a while but they don’t come up second hand very often and cost around £600 new, this one came up last spring, went to look at it and it wouldn’t fire up, the guy I bought it from practically gave it away, I paid £20, he said that it was working the last time he used it and he appeared to be a very genuine guy
When I got it home I discovered there was no fuel in it so I’m hoping its as simple as that, though they’re simple machines so I’ll get it working one way or another.
The good thing about it being indirect is that the exhaust gasses which create lots of condensation can get vented out of a window, I got the flue with it. I don’t like working in a freezing garage.
Just need to get a supply of fuel for it, either red diesel or heating oil.
Sounds good, I might he interested, I'll have to work out how to send a private message and see how much you reckon for it. CheersThese infrared heaters warm you up very quickly. Brilliant in spaces too large to heat the air. I have one surplus to my needs too….
View attachment 364782 View attachment 364783
I‘ve a wooden building with wood window frames, yeh I’ve got that in consideration, will wrap a fire blanket around it and keep a good eye on it, think it’s 19,000 btu, I’ll chain it up if needs be so it’s not touching the frame.id advise checking the heat output of that before sticking it out the window if its too hot you will melt the plastic window if you have that installed
take the whole window out and fit board/ fibre board around the flue would be your better optionI‘ve a wooden building with wood window frames, yeh I’ve got that in consideration, will wrap a fire blanket around it and keep a good eye on it, think it’s 19,000 btu, I’ll chain it up if needs be so it’s not touching the frame.
It’s a domestic garage gaz, the best option would be to run a log burner style flue out the wall or roof, that may be the way I’ll go, in the mean time I’ll just use common sense and keep an eye on it, won’t be left unattended. It’s just to take the chill out of the air for short periods of time.take the whole window out and fit board/ fibre board around the flue would be your better option
even if the window could be broken into a more secure board maybe the better option to use
they radiate the heat from a fair distance no need to have it welded to your jaxieGreat replies
It's rented and I'm only there 1 - 2 days a week so not spending money and time attempting to insulate or make small warm area.
Current plan now is duck boards and rubber mats, walking socks, layers, overalls on top, and wooly hat.
With a red rad (i think) for a blast next to me now and then
Whenever I've had to call it a day and come in from my unheated, uninsulated workshop, it's because of cold toes. Doesn't matter how good your boots are, standing on a cold concrete floor will suck the heat out of you, so duckboards are probably the best single change you can make. Dirt cheap too, just chuck a couple of pallets down. As a bonus, if the boards have a bit of give to them, they'll act as anti-fatigue matting.Current plan now is duck boards and rubber mats, walking socks, layers, overalls on top, and wooly hat.
Followed a Transit minibus burning it whilst driving allong this morning...We use a diesel space heater for our workshop which is 19th century barn. It works fine, though I am in padded shirt, long johns etc, as well as overalls. As the red diesel store is in the barn ***. However, isn't gas oil the alternative name for red diesel, when it is sold as heating oil? We have drums of waste oil, and had to pay for disposal last time we got rid of it, but DEFRA charges an arm and a leg for the licence to burn it, thus turning a useful fuel into a hazardous waste, overnight.
A walk in the woods every weekend nets some nice fallen wood.Log burner and raid the window fitters skips for old window frames (with permission of course)
Learn to use strong chromed leather gloves when doing such work if you ever do it again , they have saved me from some nasty injuries .I’m mostly stuffed where gloves are concerned - not safe where moving machinery (lathe and mills) are concerned. But a hat, these days, most certainly helps - it replaces the insulation that used to be there!
