W.olly
- Radcliffe, Manchester
I am still trying to sort this out. Now i snapped the threaded end off the what i think is an inner tube for the worm gear shaft.
This tube has an ID of around 25mm with full length keyway and is around 120mm long.
I am thinking this is an inner tube as i cant see the housing being machine to such tight tolerances for a key way to be done. Maybe i am wrong ?
What i hope is that this is an inner tube of the casing for for the worm gear to slide.
the housing
the snapped off threaded end
the other end with a bearing carrier
So if that is an inner tube in the housing and i can press it out, what are chances of if i make the tube somebody will want to cut the key way for me, or anybody knows of a person to do so ?
Just working out best way to go.
the housing
