Have you added the bird muck & dust to the total weight?Elf and safe key stuff & all that
Bacon potato and leek bake. It was a taste sensation.
https://www.bbcgoodfood.com/recipes/leek-potato-bacon-bakeAny chance of the recipe?
Maybe if you made it for her you would have more chance of a begrudging s**g.Ta. Sent to SWMBO. Tbh I've more chance of a begrudging s**g!
What material are you printing them in ?
Another weight set between rear faces will make it a lot safer if you have any reasonable weight in the vice.New vice, means new vice stand! Brakes discs, bit of tubing and extra weights if needed.
View attachment 363960View attachment 363961View attachment 363962View attachment 363963
Scrape the slag off the pieces in the bucket, and make or sell them on as airgun or rifle targets ?View attachment 363977
Today I mostly made a bucket of holes. Polo got the idea from me
View attachment 363978View attachment 363979
Customer supplied 24 plates with the 4 mounting holes in. My job was to put the ovals in them. Basic jig knocked up on table which is the purpose of this post really.
Just putting the idea out there.
It's actually very stable surprisingly, the added weights will be enough for what work I'll be doing on it. The jaw end is actually set back a bit as it was very front heavy, so I set it back to distribute the weight etc. I had a third disc and I was going to use it on the base as a triangle base. However it's footprint ment whacking my foot against it when I use. Thanks for the pointers all the same.Another weight set between rear faces will make it a lot safer if you have any reasonable weight in the vice.
As it is, to me it looks to be very front /jaw end heavy
