beardydave
New Member
- Portsmouth, UK
My bad, Isobutanepropane refrigerasnt is r290a
r600a is.... some weird mix I think :-o
Been a few years since I did refrigeration
Would not expect that, but I did put in on four concrete tiles 60x40x5 cm, with another half one under and one on top, so hope that is enough to keep it level, and will monitor, thanks.you need to support the corners and make sure they're good and flat
otherwise the doors won't close properly.... sometimes the doors are fine because the box is rigid enough..... then you load it up and the weight will twist it and stop the doors shutting :-(
Furtermore I still hope to replace the cooling unit with a secondhand single door (which opens easier) and a fixed isolated (sandwich) panel in aluminium or plastic.
Even though it is all welded stainless sheet on top?i would.
Subject to your local planning regs, I would put a false roof on it.
Torbjon Ahman did one on his gaztube channel recently.
It’s good to see what you’re doing with it.
