RaceDiagnostics
- Broughty Ferry
I've been trying to reduce my energy consumption over the last few years, driven by a goal to reduce costs, if there is a benefit to the environment then that's good but that's not my main goal. Having the kids moving out was probably the main driver to reduce costs towards the start of this process but also a few years ago we decided to use an upstairs sitting room in the winter and limit the downstairs heating. So other than the electric shower not being used so often and converting to LED lighting, we didn't really do anything else.
These energy costs were for a 5 bedroom detached house built ~ 1990 for 2018 to 2021 then a detached house for the last year built in 1900. I also put in our direct debit amount per year (year to end of August) but up to 2021 its very approximate since it involved over/under payments and adjustments, 2022 is accurate though.
I think the blip up in 2021 was due to my wife retiring and thus higher heating costs.
I was surprised that the gas figure in the new draughty house wasn't higher but I think is due to it having a new more efficient system boiler.
Over the summer we have been using ~ 5kwh of electricity a day but we have brought that down to 4kwh over the last couple of weeks by being more energy conscious, ie not filling the kettle, using the smaller of our two ovens, handwashing dishes rather than using the dish washer, turning off other low usage items. The main background use items are the fridge (~60W) and the gas boiler (~9W) so cant do anything about those.
Over the summer we have been using about 6.7kwh of gas per day, that is enough to heat enough water for showering and washing up, I expect that will only go up and the ambient cold water feed temperature drops over the winter.
Our plan this winter is to avoid turning on the gas central heating as long as possible and instead using the wood burning stove that is in our kitchen/dining/siting room. We are lucky to have this room as it means we mainly only need to heat this one room which benefits from the heat from cooking. I've no idea how long we will be able to hold out before having to put on the gas heating, or how much the wood will cost, time will tell but our goal is to achieve the following.
Pretty sure that the cost of wood heating will be much less than gas at 7p/kwh, maybe half that. If gas goes to 15p/kwh, more like a quarter.
The loft is already well insulated and I've been busy draughtproofing the front and back door but any other suggestions are welcome.
| Gas kwh | Electricity kwh | |
| 2018 Dunfermline (£150) | 30,148 | 3,746 |
| 2019 Dunfermline (£131) | 25,178 | 3,460 |
| 2020 Dunfermline (£114) | 18,993 | 3,073 |
| 2021 Dunfermline (£108) | 21,621 | 3,154 |
| 2022 Broughty Ferry (£121) | 19,500 | 2,592 |
| 2023 | 12,000 | 2,000 |
