T0rnado69
DIY nut !!
- Essex
so the comp is ready to go back together. but......
im not going to be able to put it back under the bench where it goes.
due to the pile of metal stock in the way.
getting the comp out from under the bench, we had to use a sling on the end without the handle and tip the top out and lift it over the pile of metal stock. i cant do the same to put it back now, as it has autodrain on the side of it, and i dont want to damage that trying to get the comp back under the bench.
so ive been making a frame with wheels to put this metal stock on. so i can move it out the way and move it about if needed.
using 25x25 box, ive made two U shapes and a beam between them.
got some 100mm wheels and looked for some tube ends,
the shallow ones i feel wouldn't be good enough, too short.
the long ones are way to pricey.
so i found some 30x20 bar in that pile of metal.
so i cut off four bits at 20mm long.
took the corners off on a sander and drilled them out to 10.3mm
to M12 thread them.
got one done, doing the 2nd one and then the tap holder decided to fall apart in my hands, stopping me in my tracks..
unbelievably its like anything that can go wrong, has. its like everything is trying to stop me from getting this comp together and using the plasma cutter.
thats still in the box
now i know how others feel when they say they cant get a break.
anyone know of a place that does good tap holders. (M4 - M12)
ones that can do the job and not made of cheese.
to M12 thread them.
