500e
Always buy fire insurance a flood is a hard start
- South West
will get you part No's later in weekMay I ask what sliding door gear you are using?
I used to love fixing combines, it's been twenty years since I played with one and I miss it from time to time!Made some dust, been some spell of weather to crack on, other than a slight technical issue mid week been flat out.
View attachment 359694View attachment 359695View attachment 359696View attachment 359697View attachment 359698View attachment 359699View attachment 359700View attachment 359701View attachment 359702View attachment 359703
Rats is my experience of them, eating looms, and lots of junction box covers all over the place.I used to love fixing combines, it's been twenty years since I played with one and I miss it from time to time!
What sort of tonnage?
Could be worse a friend in North Wales sent me thisMade some dust, been some spell of weather to crack on, other than a slight technical issue mid week been flat out.
I used to fit fire supression system to Combines in the past. Took 3 days to route the pipes.Could be worse a friend in North Wales sent me this
Get yourself some 2 or 3mm much easier, if you dip the tip, stop clean and re start, let the plate cool before laying your next bead once the job gets heat saturated things can get messyA mess mainly but a few I’m not ashamed of
First time ever TIG on 1.5mm AluminiumView attachment 359737View attachment 359738View attachment 359739View attachment 359740
There was a report in Berkshire yesterday of an irate picnicker standing in front of a combine because the dust it was emitting was getting in his sandwiches![]()
Last time I overhauled a combine was in Canada on the prairies. Two tonnes an acre was good going, but they'd use a swather to run two thirty foot rows together so the combine was cutting a sixty foot row. Mice were the biggest problem, especially when they didn't bother properly cleaning out after harvest. Every job I did, whatever it was, I always took a tiny gas torch, some solder and some liquid rubber and replaced every stupid 3M connector with a soldered joint. Took minutes and saved hours of time. The rest is just bits that go round and round and backwards and forwards. My doctor couldn't believe I could understand and fix something with thousands of components. I said it's easy, unlike you, I can turn the engine off while I'm working!Through the machine in total or what it's yielding. If yield then wheats averaging about 4.5 ton to the acre so far
Yeah I have some 3mm coupons tooGet yourself some 2 or 3mm much easier, if you dip the tip, stop clean and re start, let the plate cool before laying your next bead once the job gets heat saturated things can get messy
Over the years I have done some jobs I know for a fact nobody would have taken on and been successful but there have been a very small number of jobs, all of which I remember, where I know for certain nobody else could have done, these are the special jobs.
But that was the bargain - you shod anything they brought to you, anything, and the payment was that you could shoe anything.
Being the best is its own reward and price.
To quote Pratchett:
The very best people often have.Absolutely lovely man, very fragile grip on reality.
