Do you mean the coupling on the vehicle or the trailer?And? The ring hitch might be but the coupling will most likely be standard 3500kg with 110kg (S) nose weight limit.
Most like I said have a lower limit than you want.
To get higher limits you need a fixed non braked coupling and use active brakes.
You have to work to the lowest limit in the system.
Hydraulic or electric as long as they are UK spec not USA spec.Vehicle limit is 250kg
Tow bar limit is 250kg
Pin coupling limit - just checked - 350kg
Coupling limit - trying to find out
Axle 3500kg
You mentioned coupled brakes - are they still available? I know old land Rovers mentioned you could tow 4000kg with coupled brakes - I assumed they were hydraulic?
Good shout There were hydraulic over air (or is it air over hydraulic) kits available. Basically a valve that went inline to the brake system and adjusted the air pressure to the trailers appropriately.You mentioned coupled brakes - are they still available? I know old land Rovers mentioned you could tow 4000kg with coupled brakes - I assumed they were hydraulic?
since that's plated for 4t trailers (although no mention of coupled brakes as it was built pre a lot of that). Also has far more swept braking area than most similar vehicles because of the size of the pads and drums and then there's 6 of them.To go over 3500kg you cant use over run brakes.There were hydraulic over air (or is it air over hydraulic) kits available. Basically a valve that went inline to the brake system and adjusted the air pressure to the trailers appropriately.
@8ob said he had a kit he'd donate to me for the Sandringhamsince that's plated for 4t trailers (although no mention of coupled brakes as it was built pre a lot of that). Also has far more swept braking area than most similar vehicles because of the size of the pads and drums and then there's 6 of them.
My 1993 Range Rover LSE had the option for a towing uplift to 4000kg with coupled brakes was the legal requirement then. I saw an installation years ago big Gast compressor squeezed in with the V8.Has that always been true or since EU times? I'm not debating the fact that it's the law now but was it in 1983 when the vehicle was built?
As far as I know its always been that way as the old landrovers had it specified 3.5t with over run or 4t with air brakes.Has that always been true or since EU times? I'm not debating the fact that it's the law now but was it in 1983 when the vehicle was built?
Personally 10% is better but most UK cars have crappy 60-80kg limits.
I'll have a look through the paperwork I had with it but I seem to recall seeing something differentiating the Sandringham 6s against other LRs with regards to not needing coupled brakes for 4t because they had so much braking effort available on the vehicle. I may be wrong but its strange I have it in my head that's the case.As far as I know its always been that way as the old landrovers had it specified 3.5t with over run or 4t with air brakes.
It matters not what the sandringham can do.I'll have a look through the paperwork I had with it but I seem to recall seeing something differentiating the Sandringham 6s against other LRs with regards to not needing coupled brakes for 4t because they had so much braking effort available on the vehicle. I may be wrong but its strange I have it in my head that's the case.
Probably yet my 4x4 Antara with a 2oookg tow capacity has an 80kg S nose weight limit. Which is just 4% at the max.One possible reason for that could be that so many are front wheel drive.
Judging by the way my Ducato tourque steers like mad when pulling away up hill with a trailer on, it's very sensitive to nose weight and minimum front axle loading.
A much discussed problem on motor home forums.
My 2.8 JDT LWB Ducato has 2000 kg TC and has max 80g NW, but can struggle for grip on hill starts with even only half loaded trailer.Probably yet my 4x4 Antara with a 2oookg tow capacity has an 80kg S nose weight limit. Which is just 4% at the max.
However even at the max with correct nose weight it tows like a dream.
You seem to have missed my point. I understand that now any trailer over 3.5t requires coupled brakes due to EU law but I was questioning when that rule got introduced.It matters not what the sandringham can do.
Any trailer over 3500kg can not run on over run brakes.
