Hello all, I looked at a job today for a customer of mine, its a crack in a perkins engine block on a 60 KVA genset in a accoustic enclosure. The crack is around 5 inches long and runs from a hose tapping for an oil cooler through the rivets that located the engine number plate. Its on the injector pump side of the block around 1 inch below the head gasket face and runs parallel to the head. Access is good when the fuel injector pipes are stripped. I thought I would grind it out, drill the running end of the crack , preheat, stick weld it and postheat it. I have 3.2 cast rods and 3.2 cast-steel disimilars. I plan to do it on site without stripping the engine/head as I have nothing to lose by trying it. The engine has been roasted as there was also a blown core plug on the starter side of the block. I have MMA, Tig, Mig, oxy/acetylene so if anyone has done a repair like this I would appreciate your thoughts. Thanks
Regards James
Regards James
