roblane65
- Newcastle UK
Right I'll try not to ramble to much and bore everyone but lots of questions .any critique and help will be gratefully received . I finally got the transtig sorted today , downloaded the manuel yesterday had glance at as you do and dived in . I had to make a bit of an adapter for the gas out a both torches I have have got rectus couplers
so it's set up with a ck wp9F standard collet body no7cup and 2.4 tungsten ( type unknown but it was already sharpened both ends )
3mm ali wire brushed I setthe machine fq 50hz bal 65% and 100 amps and these were the results
I know I couldn't wait and a fair bit of heat saturation . I'll have a good read of the tutorial again and a better read of the manual , One big question I do have having used an old kemppi DC machine ( all analogue ) was on the control panel when I tried to set the final current Pressing the button didn't change anything on the display and I'm thinking something isn't right ! From the view on the display I'm presuming the the upslope time is a 1/4 of whatever you set the down slope to ? apart from the FC control every other function appears to work ,well the buttons do . The other thing I think wasn't helping was the table I was welding on ( it's an old makita folding chop saw table ) the ground was on the table but its only thin metal pretty dirty and uneven so maybe a clean off might help . More questions to follow
btw the piece with the four holes already had four drill holes in it
much more reading of the manual needed me thinks
has it really made a difference to welds
