backpurge
This is a classic, we used to use this photo in our gas safety training presentations, maybe shows that DA cylinders will take a fair bit of abuse, the guy is lucky he didn’t kill himself and anybody around him
Best idea, don't let someone else's problem become yours.![]()
How can you tell it’s a DA cylinder from the photoIf I was going to take a flying guess I would say acetylene bottle. If you're feeling brave you could crack it open and see what if anything comes out. Off ticket bottles only have any value if they're full or relatively modern and can be refilled (you would need to know some dodgy types who do that). Older bottles cannot easily be refilled or swapped, old valves can stick or jam at the most inconvenient moment leaving the hapless user in a bit of a predicament (ask me how I know).
None of these options are sensible. The only sensible thing to do is to find out from the local authority how you can dispose of it. There may be a cost element to that but this particular bottle represents a significant hazard and someone will at some stage need to deal with the problem.
You should step up to the plate and sort it out before there's an incident. One day some idiot is going to play around with it to see what's in it. I know I would...
Interesting. This must be where I am going wrong. I always go out of my way to help, especially when a particular set of skills are required which no one else involved might have.
First thing to do is check the cylinder outlet thread, if a argon type regulator will screw into it, it’s a right hand thread so you know it’s not a fuel gas, if the thread is the same size but the reg won’t screw in because it’s a left hand thread you know it’s a fuel gas. This may help you decide your next course of actionHi, I found this gas bottle at the back of a family member's garage. I'm looking to get set up for mig welding with gas so they said I could have it if it helped. Trouble is neither me nor them know much about gas bottles or what the colours mean. Is this of any use to me? Or is it something I could exchange at the local gas supplier?
View attachment 357582 View attachment 357583 View attachment 357584
In that case it was probably originally a tank of Co2 as I seen that marked on the valve.Google says BS1288 is "Manganese Steel Gas Cylinders for Carbon Dioxide, Nitrous Oxide and Ethylene "
BS-1288 | Manganese Steel Gas Cylinders for Carbon Dioxide, Nitrous Oxide and Ethylene | Document Center, Inc.
BS-1288 Manganese Steel Gas Cylinders for Carbon Dioxide, Nitrous Oxide and Ethylenewww.document-center.com
Stu
Why didn't you start with that.In that case it was probably originally a tank of Co2 as I seen that marked on the valve.
I thought the colour and the information on the shoulder of the tank was more relevant to indicate what the contents might be? From stuff I have read previously no one mentioned checking the valve for indication of contents.Why didn't you start with that.![]()
Nitrous Oxide
Or dead, if it isn't.There you go, you're laughing if it's that.
and your brown breadThere you go, you're laughing if it's that.
and dead if it is nitrous and leaks in a confined spaceOr dead, if it isn't.![]()
It definitely isn't, Zyklon B isn't a pressurised gas, it was sold in steel cans not gas cylinders.Zyklon B perhaps![]()
Only in the EUYou can buy this?
You can buy this?
You can buy anything with the right connections and money...You can buy this?
