RWD3M
- Wiltshire, UK
Which is annoying, but I do love the smell!.... it stinks and gives you a bad head from the fumes
Interesting .That never happens on the electricity poles on our farm.
They do come and inspect them very occasionally, and annually cut back foliage, and once actually replaced four poles but never any maintenance as you described.
That's the poles sweating it's normal , old ones used to be pickled in tanks of creosote on " Pickling Farms " for between 6 & 12 weeks , there's one just north of Tytton lane by the A16 near to Boston Lincs , think it was done on final weight after a few days draining off as to how well the poles were impregnated .never happens on the streets either you can smell the creosote and see it leeching out of the wood pole leaves a nice stain at bottom of it though
The wealthy retiree incomers didn't like to see a blue & dark brown telegraph pole outside their very very expensive riverside apartments .No, just treated poles straight in the ground. It's an 11KV three phase line.Interesting .
Do your power poles have the alloy 15 inch high or so sleeve round the base ?
I know there is a newish ultrasound test being done on tress to determine if they are sound , maybe it's being used by power companies and perhaps BT as it might negate the need for old fashioned pole hammering tests and dew point
maintenance .
if there solid you get a thump if hollow they ring a bitIt's the other way round sound gives sound a dud gives a thud .leccy board and bt just go round tapping the poles before they climbif there solid you get a thump if hollow they ring a bit
I was considering setting them on gravel
Like creosote for example?!!!....Probably best not to try it near anything combustible!...
its easy enough to make a 3mm metal container with angle iron support sealed with creosote in it with a pressure release valve of 3mm use a rocket stove along under its length for cheapness to heat it ref roman underfloor heating
the rocket stove part is sealed so flames arnt near it and the unit will depresurise itself
or the fumes off itOr in your lungs either benzine is carcinogenic I believe.creosote has benzine in it and highly flammable cant say id be exited it being next to a flameor the fumes off it
Creosote is carcinogenic, does smell nice tho.
