Question for the Boffins.....
Anyone know what the various types of adjustable SCR / Voltage Regulator/ Voltage Stabiliser devices that are widely available (Chinese mostly it seems) - are like for running my Bosch Li-Ion E-Bike Charger (input 230V, 50Hz, 1.5A, output 36vdc, 4A)?
I'm guessing the Charger is some kind of Electronic Switch-Mode Power Supply - and concerned that some devices I might add in-line to try to look after the charger & battery pack - might have the opposite effect???
Application: I want the option to recharge my ebike while away off-grid in the van. I have an old Honda EX1000 portable generator, which DOES/HAS been tested powering the Charger once - but as it's a Capacitor Regulated generator, its Voltage regulation isn't special (rather high at 255-260vac at 53Hz off-load, but drops as low as 228 as you approach its upper load limit).
In case of possible damage to the Charger (despite it seeming to work just fine) I was thinking to add a suitable (ideally low-cost) adjustable regulation device, so I can "tweak" the genset output externally to 230v before it's fed to the Charger.
I might find other uses for a variable voltage regulator device also (such as being able to vary the speed of 1ph ac motors??
TIA for any responses.
G.
G.
