Parm
Respect The Sound System
- Towcester
I hope not. It usually worn iron the wristIs this some new high tech undergarment which will shock if you watch?![]()
I have sprayed one panel so far,As said over spray can be brutal, but if managed spray gun all the way! I am currently spraying my fence panels as I build them using cuprinol ducksback, this is very thick stuff and specifically says not suitable for spraying.
I'm not letting a tin tell me what to do! So bought this
Spray Gun HVLP High Volume Low Pressure (Gun 1.8+2.5mm Nozzles) https://amzn.eu/d/5pVYc43 ( if that works) think the price has gone up but a spray gun with a 2.5mm nozzle works great. Flow restrictor wound all the way back, just adjust the pressure and pattern. No need to water down of strain the paint, 2.5mm is very forgiving when it comes to lumps
Also found the ducksback can keep in the gun for a few weeks so no need to clean after every use, handy for my situation where I'm only getting time to build a panel a week...
HVLP spray gun makes virtually no over spray, or spray dust. I painted a small car body inside my workshop once and the only mess was limited to a 3' radius around it.I dont like spraying. Last summer i bought a spray gun and after some advice from here i (sort of) learned how to spray paint some furniture
Im still picking out Farrow and Balls finest soft white eggshell from my black G shock watch
For me with limited skill and knowledge, I've concluded that spraying goes everywhere apart from where you want it to
It depends how you use the gun,HVLP spray gun makes virtually no over spray, or spray dust. I painted a small car body inside my workshop once and the only mess was limited to a 3' radius around it.
Normal spraying, even with aerosols, you end up with everything inside the workshop covered in a fine dusting of whatever colour you used.
You get over spray if you miss the target, but mine only runs 23psi at the gun, so it doesn't go very far.It depends how you use the gun,
You do get over spray,
But you can make it a lot less with trigger control,
One of my vehicles was parked 20 feet to the right side, no overspray on it, though it was dirty, from sitting in the garage, but yesterdays rain cleaned it lol, that is another story.
Devilbis JGA, 1.8mm nozzle I think,
Cuprinol Ducksback, thinned 60% paint 40% water,
I only use my HVLP's for car paint,You get over spray if you miss the target, but mine only runs 23psi at the gun, so it doesn't go very far.
I'll try it neat, as you say,Did you try it undiluted? It is thick but might surprise you. I was apprehensive at watering it down as it's got wax in it and don't know how that would work? The wax really does work though, the water beads up on the painted panels and rolls off.
Out of desperation I tried it in my little 1.2mm touchup gun to see if it would spray neat, and it did! Took a bit of pressure to get it out but worked. That's when I upgraded to the big one, not tried the 1.8 nozzle though. Here is part of my panel production line, double sided hit an miss painted inside and out, 2l of paint per panel! (Harvest brown)
View attachment 352640View attachment 352639
I can only repeat what I said about Ducksback - " blathering ducksback over my sheds every year or two for the last decade or so" - goes on, stays on, water runs off, shed looks same colour all over and shows no signs of going rotten after decade or so - one of those Tiger sheds slagged off on the shed thread as "cheap" . . .Could I ask a question about peoples' experience with the modern water based coatings? It seems to me that when you apply them to new fence panels, everything is fine. But after a few years, my experience when you want to re-coat, there seems to be a problem of poor adhesion, and pretty soon, your re-coated fence looks pretty poor? I saw a post on another forum, saying exactly this, and the lady-poster said she was absolutely in tears about it after all the effort that had been wasted.
So, are there any "tricks" to getting good re-coating? I note that nobody has thrown the use of "Creocote" in to this conversation???
creocoats crap i use genuine creosote with a few cupfulls of waste engine oil in. do the fences every 3 years and the posts are as good as new after 35 yearsCould I ask a question about peoples' experience with the modern water based coatings? It seems to me that when you apply them to new fence panels, everything is fine. But after a few years, my experience when you want to re-coat, there seems to be a problem of poor adhesion, and pretty soon, your re-coated fence looks pretty poor? I saw a post on another forum, saying exactly this, and the lady-poster said she was absolutely in tears about it after all the effort that had been wasted.
I have some proper creosote (about 40 litres of it)
