julianf
- devon, uk
Defender 300 tdi clutch pedal -
Not been on the road since 2015. Clutch was bled. Seems to work fine, except....
Sometimes when i go back to it, its on the floor. As in has fallen, against the physical springs, and is on the floor. Must have been sucked down?
If i lift it manually, as soon as its over the "cam" point of the spring, it lifts up to normal position, and behaves like any other clutch would again, rising up to where it should be, no detectable fluid loss - works just like you would expect.
Stays like that a day or two, or whatever, and then, when im not looking, mysteriously drops down to the floor again.
You dont have to pump it to regain it once its lifted - just seems to be as if it had never happened the moment its lifted back up again.
Any ideas?
Thank you.
(i know this isnt a car forum, but, well....)
Any ideas?
Thank you.
