W.olly
- Radcliffe, Manchester
Or Ally oxideYou want them soda blasting, not grit
or that special sand from wickesOr Ally oxide
or that special sand from wickeslovely finish on ally and fast removal of crap and paint
yepVolvo Penta ?
Mounting color is already off and ready to blast, remove the UJ and prop seal it all then blast it., then run fast lolYou going to seperate all thé pièces, and replace thé rubber gaitors, or just blast them and runaway ?
Just curious.
as long as you can achieve 28cfm that will be good on a 3.0mm jet. any less and your flogging a dead horseOh yes all sorted now, going to try a pot on my kit and if it dont do it ill get another compressor. just found a cheap pot.
its called clean all the parts after you have blasted them and remove anything that can be damaged like bearings and seals . aerospace beadblast a lot of there parts along with other manufacturersAnd fine sand everywhere you don’t want it, eating bearings and seals
I'm glad you told me that, i guess the experience gained from rebuilding alu block aero engines was worthless in this scenarioits called clean all the parts after you have blasted them and remove anything that can be damaged like bearings and seals
completely different situation there, but ok![]()
Aerospace – Guyson International Limited
Guyson's industry-leading surface finishing solutions are the go-to choice for various finishing applications, in the aerospace industry.www.guyson.co.uk
It’s ok. I’m fed up of telling him about the risks of exposure to sand, even bought it up with the modsyou will be getting banished from here with that talk![]()
