Kayos
Gone......
- Yorkshire
I know this is is a very common failure mode & suspect it is caused by the back EMF when the valve closes. Also observed it on the bridge rectifier feeding the gas solenoid valve, but being technicians with limited service time board change is the order of the day
RonA
I'm sorry but appliances with an on/off solenoid valve do not have this as a very common problem or indeed bridge rectifiers, they use AC solenoids
A modulating boiler has a very different mode of operation, back emf doesn't interfere with the boards.
Boards do fail, it is a consequence of more complicated appliances. Time limited is often correct, a good engineer will diagnose a PCB quickly but is unlikely to have the skills or equipment to repair it.
Modern boards also have to be designed so component failure external to the board doesn't damage the board, in theory makes diagnostic easier and less costly, but further adds to the complexity
