I could only get NO to work with my board. What board are you using?
Grbl Arduino based I believe.I could only get NO to work with my board. What board are you using?
Its looking good apart from that though!!Trials and tribulations.
Pocket holes went well.
Workholding not so much.
4 holes around the outside and screwed down with double sided tape holding the middle.
Must have let go as the tabs were cut through on a middle piece.
Vibrated a bit loose and broke the bit.
Set up to have another go and forgot to swap to outside the line.
Spray glue. More CF and some new bits arriving tomorrow for another try
View attachment 350642 View attachment 350643
Bushing in the z axis vibrated themselves out today. Gonna have to try and sort them out.Its looking good apart from that though!!
That's my plan. Needed a reference to start from. For the £120 I paid it's giving me it's money worth both in functionality and experience.It's interesting what can be done with these machines, but they're never going to be a great machine, as they are built to a price.
Main thing I'd recommend them for, is learning the basics, and to guide people to what they actually want from a CNC router.
When you start upgrading them, you start entering the realm of chasing small gains, which are never going to result in a great machine, until you've replaced pretty much all the components.
You're far better to just built something from scratch, using good components, as you'll usually end up with a far better machine that requires far less tinkering to keep running well.
To give a basic list of what's needed to build what should be a reasonable machine-
Alu extrusion for frame and gantry (you can use steel for the frame, but you'd either have to bolt it to get some adjustability, or have it machined flat once welded).
Aluminium side plates (at this size of machine, 8mm or even 6mm would do, as they can still be cut reasonably easily with a jigsaw)
Linear rails (you ideally want something with medium preload - beware cheap rails are often zero preload, meaning you'll get movement between the rail/carriage under load, which can be quite noticeable once you allow for the leverage involved)
Ballscrews (rolled screws (C7 and over) with anti-backlash nut setups are usually OK, but ground (C5 and under) will reduce play, but extra cost can vary between minimal and make sure you're sitting down depending on size)
Proper ballscrew support bearings (even cheap C7 bearings will usually result in a noticeable improvement over the typical screw endfloat control on these machines.
Electrics/electronics wise, there are lots of options.
I could list pros and cons of lots of options, but if you're upgrading from one of these basic machines, swap the electronics, then upgrade/change as things break or you need/want more performance.
It's a good plan.That's my plan. Needed a reference to start from. For the £120 I paid it's giving me it's money worth both in functionality and experience.
It's been on my to do list for years so I'm just pleased to be heading in the rigt direction.
It will be the groundwork to an 8x4 machine when I have the room.It's a good plan.
I've seen far too many people chasing perfection with these kind of machines, and with the amount of time/money/wasted materials they spend, they could have just built a better machine from scratch.
My problem is I ignored the type you have as just an engraver.It will be the groundwork to an 8x4 machine when I have the room.
Only been talking about it for the last 3 years.
All in this machine has cost me £160 il go no further other than the necessary to keep it running now.
It's limitations were clear before I bought it. But that one off job spured me on.
... double sided tape holding the middle.
...Spray glue.
