Lugh Lámfada
New Member
- West Of Ireland
The 3 behind the leg vice will have to be for another day, nut going to dig them out now
No sorry.Don’t suppose you two have done a colour match on those parkinsons, ie taken it to a paint shop and had a formula analysed would love to know the colour
Had one a while, posted pictures a while back. One day I will use it to set and sharpen a saw blade. Think mine's a Disston (?),Yes it is.
And it is MINE MINE MINE.
Nobody with a tidy bench ever did anything.Record imp. In all it's unrestored beauty.
One i never actually researched, a Dinky
A zyliss, lead screw is sightly bent unfortunately, so will need a little work at since stage.
And the pièce de résistance!
My main working vice, no name record knockoff I suspect, probably 40-50 years old, it's been beaten, weld splattered, drilled, pieces broken of, etc. But still going strong ish. Belonged to my grandfather, so it's staying on the bench.
Editing to say, please excuse the current state of my work bench, but really it nearly always looks like that!
I remember my Dad had a Disston saw vice similar to yours, except it had a ball on the lower end which fitted into a bench clamp so you could adjust it to about any angle. Don't know what ever happened to it.Had one a while, posted pictures a while back. One day I will use it to set and sharpen a saw blade. Think mine's a Disston (?),
Can send you my disston if you would like to sharpen it! ;-)Had one a while, posted pictures a while back. One day I will use it to set and sharpen a saw blade. Think mine's a Disston (?),
I believe at the bottom of mine there is a 'thingy' which allows you to tilt the main vice. I can only compare it to the arrangement of a bicycle saddle. I'll dig it out tomorrow as long as I don't find anything too exciting at the car boot!I remember my Dad had a Disston saw vice similar to yours, except it had a ball on the lower end which fitted into a bench clamp so you could adjust it to about any angle. Don't know what ever happened to it.
Believe I have a Disston in the shed somewhere, apparently they are excellent saws. Though being an ex spanner monkey I find it to long and unwieldly, I prefer a Japanese saw.Can send you my disston if you would like to sharpen it! ;-)
Was a recent project to clean it up and rehandle it.
No vice in this post, but the handles 'clamp' on.
Edited again, actually the record 00 is in the first pic :-)
I noticed that in your previous photo. Seen the same sort of thing before on an old branch trimming saw we had that was on a long pole. You could adjust the saw by unscrewing a wing nut then retightening it when a more efficient cutting angle was desired.I believe at the bottom of mine there is a 'thingy' which allows you to tilt the main vice. I can only compare it to the arrangement of a bicycle saddle. I'll dig it out tomorrow as long as I don't find anything too exciting at the car boot!
Steve
Thanks as always CarstenHi
Of course, right at the beginning, when you introduced this new acquisition, I felt called to say something about it.
Unfortunately, I have not been able to make a clear classification in the meantime, but I can share my observations:
- The design clearly points to a German manufacturer, whereby one must understand Germany in its largest extension, thus also including Poland, Kaliningrad, the Czech Republic, Austria and other areas, because large foundries are notoriously difficult to move and take with one when the enemy approaches;
- The "piggy nose" is more often seen on German vises and not a specific feature of GDR vises - you only need the outermost radius to drive the spindle, steel was always expensive and in the East they adopted all the material-cutting measures and in many cases pushed them further;
- This vice has strong similarities to Eikar, manufactured by Breitenfeld & Scholz in Bunzlau, now Bolesławiec in south-west Poland.
There, too, one could not save much more than one's naked skin when one fled, and so a successor company in Poland later had a good start.
- However, I also see differences, e.g. I haven't seen the captive nut in the cast on the underside anywhere;
- But what I think I can say for sure is that it is not from socialist production:
Obove is clearly a measure to "convince" the customer to continue buying all spare parts and accessories from me in the future.
Breitenfeld & Scholz had some patents to enshure exactly that.
This is the exact opposite of the "use of identical parts" as it was practised in the East and is also today in large companies.
(That's why today I sometimes like to work with equipment made in the East, for example: A watchmaker needs a timing machine, and the Swiss and German manufacturers have outdone themselves in making the paper strips smaller and the ink ribbons more and more exotic in order to secure follow-up orders.
The opposite was true in the Eastern Bloc: there was essentially only one timing machine,
the PPTsch-7m
View attachment 350137,
which everyone had and which had to run everywhere. Consequence still today: any ordinary typewriter ribbon and a normal cash register roll fits for working and recording).
- For me, it is also clear that the specimen is a pre-war vice from somewhere in the (former) German-speaking world; in the East, these extravagant jaws would have been an immediate thing of the past.
Keep us updated when you find out more,
will do the same.
Carsten
has the usual matching cast numbers, has EL stamped into the spindle nose
yes I believe they may be, mine have a clear “.” After the numberAre the fonts of your casting stamp comparable to my copy?
Your EL seems to me to be from the same font family?!?!?
Carsten
