gasket999
getting there...
- Manchester, UK
Quick one folks.
Some years ago I bought a few manifolds for a workshop air system and I’m finally fitting them.
The plan is to have the air come in from the top, a line leading to a ball valve coming from the bottom (for drainage) and three quick connects in different formats coming out of the front.
No worries there. Except one of the female threads in the manifold (the top one) is just plastic and doesn’t have a brass insert. It’s obviously part of a proprietary airline system, but I just want to use it with 15mm copper pipe.
Could anyone advise how best to use this port? I’m not sure whether to just carefully use brass BSP (taper) male fittings, whether to buy some sort of plastic make fitting or to just block the port with a plastic/brass bung and use the manifold upside down (I have plenty of other drops and drains in the system).
Any help would be very welcome - the last thing I want to do is to tear the threads and ruin the manifold.
Thank you.
Thank you.
