Many years ago (1974) I worked with a chap who had a friend that was in an airplane crash. He said his body was terribly scarred due to wearing nylon shirts and crimplene trousers that had meltedDenim is as good as anything for resisting sparks, avoid polyester and fleece at any cost they melt and stick to you.
Well obviously I'd have my steel toecaps on too...and *nothing* else![]()
Well obviously I'd have my steel toecaps on too![]()
After the Falklands the navy went from man made fibres to FR cotton working dress, lots of people got badly burned due to unsatisfactory clothing when escaping/fighting fires on board ships.Many years ago (1974) I worked with a chap who had a friend that was in an airplane crash. He said his body was terribly scarred due to wearing nylon shirts and crimplene trousers that had melted![]()
If I'm doing sustained grinding I make sure the sparks are angled away from me, if I can't avoid the sparks I use a leather welding apron![]()
I had a leather apron with an A4 sized sheet of 1mm plate rivetted onto the most vulnerable area, as even the leather gave up after a while.
Is the photo for inspiration to form your plain looking 1mm plate into a decorative codpiece?![]()
I set fire to a scruffy pair of frayed jeans when I was taking welding classes at a local college, many years ago. I had two pairs on, as I was a scruffy biker then and it was winter, and the top pair caught alight. I remember feeling something 'tickling' my leg while was welding, so I finished the weld run and looked down....Denim is as good as anything for resisting sparks, avoid polyester and fleece at any cost they melt and stick to you.
while singing" I am what I am" by Gloria Gaynor.Leather jacket or apron depending on the weather.
It looks like an armoured bear from "His Dark Materials" to me.
Chanel No5 Dahling!Merrily grinding away, sparks hitting my overalls, my leg started to get a bit warm... I look down and i'm on fire. Cue grinder rapidly goes down and I start hopping about like a madman trying to pat out the fire. A clean hole in my overalls and a burn mark on my trackies is the result. Lucky it wasn't worse.
What do you wear when grinding?
