- Birmingham
Break in through the window and attack the lock area with an axe from the inside then get them to report it as a burglary so the insurance can sort it to their high standards?
Wish them good luck, close your door, have a cup of tea and a few chocolate biscuits, read the paper.
This is firmly planted in the 'somebody else's problem field'.
Tell them to read their insurance policy to see if it covers broken locks and leave them to it!Break in through the window and attack the lock area with an axe from the inside then get them to report it as a burglary so the insurance can sort it to their high standards?
No good turn goes unpunishedWell I cracked the lock! I put the key in the lock, turned it as far as it would go and backed it off slightly.
Then I got a spare bit of cycle inner cable and fed both ends in, back towards the rear of the lock .
I pushed it in and back a few times and turned the key as I did it.
Click! I’d lifted the obstruction enough for the bolt to retract and it was undone without any damage.
The fault was as I suspected with two bits of spring coils sitting on the bolt guide pin.
This is a lethal design fault as you could get locked in a sealed room during a fire.
They were overjoyed at no damage whatsoever.
The kicker: Can you do the Sons bike, brakes have failed and the chain keeps coming off. You’ve got to laugh.
. I don't mind helping folk, but I draw the line at someone extracting the urine, which it sounds like your neighbour is doing
.The kicker: Can you do the Sons bike, brakes have failed and the chain keeps coming off. You’ve got to laugh.
The office was spotless and SO tidy. It didn’t look like any work ever went on in there. They’re obsessed with extreme tidiness.@Alan Reynolds
Did you find out what big secret he was hiding in his office that required it to be locked?
