hotponyshoes
- Somerset. Uk
Couple of questions for those familiar with routers (the wood type not computer!)
Is the guide edge on a fence supposed to be dead straight?
I had a cheap router with a pressed steel fence and that was all over the place although that's about what I would expect for the price of the tool..
Anyway, I purchased I used router which was originally a better quality machine and the fence for that also had a slight bow.
I then purchased another (again previously used) fence only and that one is slightly bowed as well.
In the photo I have adjusted the screws to exaggerate the bow, it's only about 0.25mm but as it is present on both decent fences I'm wondering if it's supposed to be there?
Or if they have both previously been abused although I can't see how you could twist one without cracking it?
Only asking as I need to make up some new cheeks and I don't know if I should make them flat or not?
Also, a slightly more specific question,
I have a bosch FSN OFA adaptor plate (used to mount a router to the track saw type rails)
Supposedly it's compatible with a bosch GOF router.
My specific GOF900ACE should use set of holes 'A' but, for a start the router does not have any spare threaded holes in the base plate. I though maybe the 3 screws holding the plastic plate on might need to cone out but none of them line up with anything either?
Am I missing something obvious here?
Or, is the adaptor only suitable for the current, chinese built GOF models and not my older, smoother, usa made GOF?
I have got some decent sheets of nylon that I could make an adaptor up from but then I'm going to loose 20mm of plunge depth capability I think...
